Did 700R4 come in 83 Z-28?
Car: 84 Z28 Camaro
Engine: 350ci
My friend has access to three 83 Z28's. His
question is what auto trans came in these
cars? RPO code MX0 is the option code for an
auto in 83 Z28. Is this the 700R4 ?
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Tom K.
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
MX0 just means it has the provisions for an automatic trans, it was OEM equipt with an auto. Look for MD8, that is the 700-R4.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited July 18, 2001).]
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB
Car: 1983 Z28
Transmission: WCT5
I didn't think any other auto trans. came in any of the thirdgens after '82. correct me if I'm wrong though...
I thought anything '83 or later with an auto was a 700R4
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Clem
Transmission: 4L80E/4L80E
According to https://www.thirdgen.org/newdesign/tech/techdb.shtml , the A3 or TH200C was still available in '83, as was the A4 or TH700R4. That's consistent with other sources I've seen.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 82 camaro SC
After that many years, the tranny may have been changed. Check the tranny to make sure.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 1983 Z28
Transmission: WCT5
According to the data in the link, the only auto available with the V8s in '83 were the overdrive (700R4)...I think
and like leo said, it's pretty easy to tell whether you've got a 3 or 4 speed auto...
Clem
Clem
<font face="Verdana, Arial" size="2">Originally posted by clemsparks:
Clem</font>
Clem</font>
Car: 1983 Z28
Transmission: WCT5
well,
I really don't mean any offense and it's not a big deal, but I only see A4 and M5 listed for anything with a V8, In 1983. maybe I'm missing something, or we could be on a different wavelength altogether.
bygones...
Clem
[This message has been edited by clemsparks (edited July 19, 2001).]
bygones...
Clem
Engine: was: L69
well,
bygones...
Clem</font>
well,
bygones...
Clem</font>
You're right. I wasn't looking close enough at the engine that went with it. My bad.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
