4th gen pedal assembly for T56
Old Apr 12, 2009 | 01:22 PM
einarak's Avatar
Car: Camaro RS
Engine: 327
Axle/Gears: Alloy axles, motive 3.73
Do manual transmission V6 and Lt1 4gens have the same pedal assembly and the same clutch master and slave?
I put T56 in my thirdgen Camaro (original 5 speed) and reused the thirgen pedal assembly. It dosen´t work as well as I was hoping for and I want it replaced with forthgen´s assembly... The problem is I´ts pretty hard to find a pedal assembly from a v8 car localy so I was wondering if it is the same for the V6 cars? Or Is there a way to modify the one I have?
Old Apr 12, 2009 | 02:12 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
Re: 4th gen pedal assembly for T56
i dont see the pedal assemblys being different on the 93-97 4th gen pedals. when i had a lt1 t56 in my iroc i used the stock thirdgen pedals, and used a modified bushing and e-style clip like whats used on the brake booster rod, and mine worked just fine.
as for hydraulics, i would try to stick with hydraulics for the v8 car unless you can cross reference part numbers and they are the same
Old Apr 12, 2009 | 04:05 PM
einarak's Avatar
Car: Camaro RS
Engine: 327
thank you, I allready have the hydraulics from lt1 car, just want the pedals. With the 3rd gen petals, I only have to step the clutch for about 1-2" to fully release the cluch... It´s all the way at the top.
Old Apr 12, 2009 | 05:40 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
the pedals will work with in the 3rd gen, of course you gotta modify them some. I did not expierience the problem you are having though when i ran the same setup
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
