Where can I get a 3.90 speedo gear for the 700-r4?
Old Jul 19, 2001 | 12:17 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I have a Moser 9" rear end for my equipped with 3.90 rear gears. I want my speedo to read correctly though. Where can I get a speedo gear for that gear ratio? Who makes custom ones?
Old Jul 19, 2001 | 10:34 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I don't think you can get speedo gears for that ratio. I have never heard of custom ones either. You could put 3:73 speedo gears in and be pretty close. I think that the 3:73 gears arn't that accurate anyway.. now that i think of it i am not that much help. Interesting question though
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    !cat
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
    Its for sale!!
    Email me if you need a decent back up car
Old Jul 19, 2001 | 04:36 PM
Jay 727's Avatar
There are places out there that can make a gear box for any possible combination. It's a little aluminum box with small gears inside that bolts to the trans and the cable bolts to it (screws to it). I don't remember who but you tell them what rear gear, tire diameter you have and they'll make it.
Old Jul 19, 2001 | 04:48 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
auto meter sells a lttle black box to calibrate your speedo it has two notches on it that you turn with a screwdriver to set a driven gear count and a drive gear count however that is electronic your vss plugs intto it if you have a cable driven speedo i don't know if they have one for it
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete.
shooting for 13's!!!!!!!
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 19, 2001 | 10:28 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
IF they made them you would need a 15:47 or a 14:44 combo. The 15 tooth drive gear is easy, the 47 tooth driven is not. And I doubt a 14:44 combo exists.
The 3.73 combo exists, not because GM installed 3.73s with an automatic (I believe that 3.73s were only available on HO L69s with a 5-speed BTW), but because it is a combination of existing drive and driven gears in late model years.
BUT, you should contact a GM dealer (or auto parts store) and see if such a gear (47 tooth driven gear) is availabe on another variant of their cars.
Old Jul 20, 2001 | 04:43 PM
Pro Built Automatics's Avatar
If your tire is is 26" the the 15-45 combination will work, if the tire height is close to 27" then the 15-44 will work. If the tire height is somewhat shorter than 26" then you will have go to a speedometer shop to have it dialed in.
Glad Too Help!!!
Old Jul 23, 2001 | 04:44 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Glenn, 84 was the only year you can get an L69 with an automatic. 83 and 85-86 the L69 is 5-speed only.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
