LT1 T56 with a LS1?
Old Apr 13, 2009 | 02:23 PM
noecker55's Avatar
Car: 1991 Firebird T-Top
Engine: 305 tbi
Transmission: t-5 manual
Axle/Gears: 3.08 Open
LT1 T56 with a LS1?
So I've been looking around for awhile and i was wondering if a LT1
transmission would bolt up to a LS1 engine. I was hoping to do the swap sometime in the future but the transmission will be going in long before the engine and I've read the LT1 T56 swap is easier to do.
Anyone who has done this or knows if this is possible please let me know.... thanks in advance
Kyle
Old Apr 13, 2009 | 07:29 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: LT1 T56 with a LS1?
The bellhousing/block bolts will work (except one), but the shorter LT1 input shaft, and deeper LS1 crank will leave about 3/4" between them, and trash the inputshaft/crank.
Short of buying a conversion bellhousing ($$$), you won't be able to make it work easily. You could keep your eye out for a LS1 Input-shaft, Mid-plate, bellhousing on classifieds while you're building/saving for the LS1 motor, since they are the only things different between the LT1 and LS1 T56 versions. (and someone to swap them for you correctly)
Old Apr 14, 2009 | 09:32 PM
noecker55's Avatar
Engine: 305 tbi
Thanks Mike, this was exactly the info I was looking for
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
