non lock up breakaway converter .. will it harm 700R4 ??
ive heard on here somewhere or from somebody that it would shorten tranny life.. just wondering if that is true cause my tranny just quit after like a week or 2 .
350 bored 30 over ..882 casting heads ..comp cam..hooker headers.. 700r4 corvette servo .. 3.73 and SLP posi no hood on the car , holley 750 CFM, performer RPM intake.. and umm couple other things here and there
Is the "Breakaway" torque converter a 12" stock diameter? If it is, and does not have the clutch in the torque converter, then it will produce more heat depending on the rated stall and rear end gear ratio. I have seen many problems with these type of torque converters (stock 12" diameter with the clutch removed) running hot. If you do not want a TC clutch then go to a smaller diameter 10" Continental with 2,200-2,400 rpm stall or equivalent. I use many of these type of torque converters (10") with no heat problems. The stock torque converters were not designed to run without the clutch in overdrive (most heat/highest load).
Hope This Helps!!!
Hope This Helps!!!
i have a tranny cooler would that help enough ? so the tranny shld be OK then right ??
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I am running a non lockup converter on my 700r4 and I have experienced no problems. NO overheating. My next upgrade 700r4 will go with a non lockup also. Just be sure and put on a trans oil cooler.
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,2500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.
383 86 Camaro Z28
There are people that swear they have had problems with it and I believe them. I do have another take on the problem though. A 350 turbo can come in a lockup or a non-lockup version. I know plenty of people running a lockup version and not using the lockup. They have had no problem with it! What is is that cooks the tranny in the 700 when it isn't locked up.
I have fried a couple form the stupid in and out of lockup problem they have. I would think that would cause a lot more heat than not having the tranny locked up. I am no tranny man and pro built knows his stuff, so I would just like some explanation. It all seems like a lot of fairytale when this topic comes up.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by purpleworm:
</font>
</font>
Car: 87 Formula Firebird/ 84 Trans Am
Engine: 305 / 305 H.O.
Transmission: 700 argh 4 / same
I had a question somewhat like this a few months ago. It was never answered. My tranny went and when I was doing the removal I found the lock up wire form the computer was cut! I wonder if that's what killed my 700?
You put Mt. Dew in the gas tank!?!
Wow, look at it go!
1984 L69 305HO WS6 Firebird Trans Am
Current Mods[*] 2 1/2" Flowmaster cat back[*] gutted cat[*] 160 thermostat[*] all around polyurethane bushing kit from Energy Suspension[*] 3.73 Disk rear
Mods to come![*] 350 .30" SB [*] Comp Cam[*] Edelbrock RPM Proformer Package [*] 3.73 Posi Disk rear[*] Edelbrock TES headders - Yeah I like em![*] 150 lb shot Edelbrock Nitrous System[*] Edelbrock Aluminnum Signeture Series Valve covers.[*] 140 amp GM High Proformance Altnator
Wow, look at it go!
1992 Trans Am
May 10, 2023 07:19 PM
C409
Sep 1, 2015 03:42 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
