TH350 swap?'s
Old Jul 24, 2001 | 03:21 PM
BlakCamZ28's Avatar
TH350 swap?'s
What has to be done to swap a TH350 in to a car that was originally a T5? I know you have to change the pedal assembly, run tranny cooler lines and it requires a different torque arm, what about the crossmember and driveshaft and kickdown cable? and any stuff i'm forgetting?
Old Jul 24, 2001 | 06:03 PM
ede's Avatar
ede
the torque arm is the same. you need the shifter and cable. you can cut the clutch pedal if you don't want to remove it. you'll need b&m part 30299 to adapt the cross member and torque arm.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
LittleFranks
Sep 17, 2015 12:22 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
