If it burns both tires in reverse and only the left in forward gear.....posi??
Old Jul 26, 2001 | 08:13 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
Is it a posi??or is the factory posi just broke in forward gears??
Drive it like you stole it
Old Jul 26, 2001 | 09:59 AM
82camaro's Avatar
Car: 82 camaro SC
It sounds like an open rear to me. An open rear can burn both tires in reverse and forward, just not every time. It doesn't mean it posi or not. Pull the cover to be sure.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
E Rod
Aug 28, 2015 05:17 AM
bdads
Aug 24, 2015 06:01 PM
mizz0313
Aug 12, 2015 06:45 AM
