i fu**ing HATE my 700r4, please help
Old Jul 27, 2001 | 06:00 PM
kernel's Avatar
i am new to using this automatic tranny and dont know if it is supposed to do this or if there is someway to fix this. okay, i get really good pickup from 0-60 then after i hit 60, i dont get good pickup at all. it seems like it is shifting from like 2nd gear to 4th gear or something. is there a kickdown switch or something to fix this. anyone else have this problem?
1986 WS6 pontiac trans am
5.0 305 TPI V8
700R4 tranny w/transgo shift kit. borg warner wires,accel cap and rotr,delco plugs, K&N
KYB shocks
"ponys can run but birds can fly"
Old Jul 28, 2001 | 12:14 AM
u r sofa king we tah did's Avatar
what gears do you have in your differential?
Old Jul 28, 2001 | 08:29 AM
Jay 727's Avatar
It's normal, I don't know why they designed it like that but looking in Jegs I see a "th700R4 kickdown kit" for $33.99,
, it's a valve that replaces an existing one in the valve body. It says it corrects the kickdown problem at 1/2 throttle and will change the kick down point to 3/4 throttle making highway cruising in fourth gear possible.
It depends on what year trans you have, some later than '87 kick down at higher speeds, it is a pain in the *** though. I had a '86 with a trans go 2/3 shift kit and it allowed full throttle cruise in fourth, I guess you have a different kit.
Old Jul 28, 2001 | 09:50 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Just a peanut cammed 86 305.
S L O W !
You expected a Big Block?
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
sammy52401
Nov 11, 2015 07:20 PM
Fanatic1074
Oct 2, 2015 03:47 PM
6998poncho
Sep 25, 2015 02:56 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
