ATTN: RB83L69
Old Jul 31, 2001 | 07:41 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
ATTN: RB83L69
You are a genius!!!!!!!!!!!!!!!
My noise that I've been hearing was the E-brake adjustment bracket rubbing (sitting) on the driveshaft.
Every time that I got under the car, I had the E-brake on which pulled the bracket up so that it was not touching the driveshift. Last nite when I got under the car, I let the E-brake off, and sure enough it was on the driveshaft.
During my wheel hop episode, the passenger side wire just behind the adjustment bracket had popped out of the channel bracket that is mounted on the bottom side of the tranny tunnel. So I simply pushed the brake wire back into the guide bracket.
No more slinky noise!!!!!!
I dont know why the noise was coming from the front part of the console up near where the TC is located.
Thanks.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Jul 31, 2001 | 03:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It made its noise seem to come from way up there because that's where the end of the cable is, right under the p-brake handle.... just like a violin, you don't hear the strings themselves, you hear them vibrate the body of the instrument.
Don't ask how I know where that noise comes from if you haven't already figured it out
ICON Motorsports
Streetiron85
May 15, 2008 01:16 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
blue305rs
Jul 8, 2003 07:04 PM
90TA
Jan 20, 2003 09:05 PM
