lock up torque problem
Old Apr 21, 2009 | 10:55 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
well i changed my tranny in my 87 iroc and put in one from a 4.3 van.the trans works good but my torque seems like it kicks in as soon as i get into 2nd gear at any speed.i already got rid of my old one so i dont have it to look at.when i installed the shift kit i saw only one solenoid and one button lookin switch that didnt thread into anything just bolted to the valve bodie and had 2 wires plugged to it.id like to get the torque working right.i have a switch i hooked to it for now to lock it in when i get to crusing speed but5 thats aggrovating lol.any help or ideas???????
Old Apr 21, 2009 | 09:03 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: lock up torque problem
Did you unplug the harness mounted to the valve body? If so, one of the pins may be bent and shorting locking the conv as soon as it shifts into second. I tweaked the plug on mine, and had the same problem. Another thing to check is the lockup solenoid itself, it may be stuck.
Old Apr 21, 2009 | 09:34 PM
Car: 87 iroc z
Engine: 358 tpi
no i didnt have the pan off or anything when i first changed it i put the kit in way later. and i guess the noid is good cause i have a switch wired in it and when i turn it of it wont kick in is there any way to check if it is stuck ?if not i guess either the other tranny was wired diff or my ecm isnt telling it right or my speedo is somehow messing with it any ideas at all would be great
Old Apr 23, 2009 | 08:50 AM
Car: 87 iroc z
Engine: 358 tpi
found the problem the solenoid was bad and stuck on i took the pan off for a diff reson and thought i would check the noid and it wouldnt do anything so i changed it not drove it yet but im shure it works right now
BRoss99
Aug 10, 2025 05:08 PM
zayne0
Aug 24, 2015 07:22 PM
CORV3TT3
Aug 23, 2015 11:26 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
