stall converter lockup
Old Apr 22, 2009 | 04:42 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
I'm going from the stock 305 with TPI to a carbed 355 setup. My transmission is a built 700r4. I recently purchased a 3200-3600 vigilante lockup stall converter.
My question is with a stock setup, when does the converter actually lockup? Does it lockup under WOT and when cruising? Also, since I have swapped to carb and am lacking a computer, am I going to have to manually toggle the lockup action of the converter?
Thanks.
Old Apr 22, 2009 | 04:51 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: stall converter lockup
The stock setup locks up the converter in 3rd or 4th under cruise conditions. It unlocks when the brakes are applied, it downshifts, or you accelerate. B&M, Painless, and TCI all make kits that control the lockup in 4th gear automatically with no computer required.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
amcnellis
Sep 16, 2015 04:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
