series-2 with 3.73 gears?
Car: 1987 Z28
First how do I even tell what carrier I have? I have a 1987 camaro z28 that came stock with a 305 TPI automatic. As far as I know the rear is stock, at least i never changed it. I'm assuming its a series 2? and that its a 10 bolt 7.5?
So if it is a series 2 carrier can you put 3.73 gears in it? I'm confused because I thought you couldn't but on Richmond's wed page it has a part for 3.73 gears for series 2 carriers but it also says series-2 Fits 3.08 and numerically lower carrier. 3 Fits 3.23 and numerically higher carrier.
thanx in advance for clearing up the confusion
Car: 1987 Z28
Re: series-2 with 3.73 gears?
how do i do that? i looked at the camaro tech data and it says 2.73 so i guess thats what it is because i never changed it before
So if i do have a 2 series then i can get 3.73 gears?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sure. Check the following FAQ for info that will be helpful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
Car: 1987 Z28
thanx for the link I guess i should have checked there first. So is it safe to assume that I have a series 2 carrier? (i cant check the cover because it was replaced) I'm assuming this because, if I'm reading the tech data right, it says that an 87 z28 auto came with 2.73 gears
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
