Posi or not?
Old Aug 6, 2001 | 08:51 PM
THE SANDMAN's Avatar
Car: 1983 Camaro
Engine: 5.7
Posi or not?
I have an 83' Trans Am as a project car and I would like to know what gears would be in it? Also would it be Posi or not? Thanx.
Sincerely, THE SANDMAN
Old Aug 6, 2001 | 08:53 PM
Car: 1983 Camaro
Engine: 5.7
Please do not ask why I posted this twice because I have no idea why I did it either. Sorry!
Old Aug 6, 2001 | 09:55 PM
82camaro's Avatar
Car: 82 camaro SC
depends on the options(rpo codes)
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 7, 2001 | 12:47 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
look on your RPO list for all the "g" codes. if you see G80 you have posi. For the gear ratio, you'll have to enter all the "g" codes into the RPO decoder on this site. One of them will be for the gear ratio.
Eric
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
