T5 Flywheel bolts different from auto ones?
Old Aug 5, 2001 | 07:58 PM
86IROC305's Avatar
I was looking over the tech artical on sawpping an auto/T5 and it says that I can't use the flywheel bolts from a auto on a manual flywheel, unfortunatly I don't have them. The donor car didn't have a motor/flywheel so I had to buy it seperately.
Where would be a good place to get the bolts I need and the rod that goes between the release fork and slave cylinder? Thanks
Old Aug 5, 2001 | 08:00 PM
camaro6spd's Avatar
you can't use them b/c the flywheel is thicker then the flex plate of the auto, just get some high grade bolts from your hardware store.
Old Aug 5, 2001 | 08:28 PM
86IROC305's Avatar
Thanks, Anyone know where I can get the little push rod that goes between the slave cylinder and fork (or the correct length, if I have to make one). Also is it possible to remove the master cylinder from the flexable line to replace it(I think mine's locked up ) Thanks Again
86 TPI 305 Iroc-Z
700R4 (rebuilt)
9 Bolt Rear Disc Swap
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Aug 7, 2001 | 07:18 PM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
I picked up the flywheel to crank bolts at the dealer, were only about $1 each. I figured that was the safest way to go.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Trickskier
Aug 29, 2015 01:12 PM
355tpipickup
Aug 25, 2015 12:54 AM
