10 bolt to 9 bolt BW
Old Apr 26, 2009 | 10:31 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
I have a 10 bolt drum brake setup wanting to change to PBR rear disc.
Is it worth just getting plates to mount the rear disc on the 10 bolt or just swapping out for the 9 bolt?
I have the e-brake cables from the 9 bolt but what else do I need to change?
Both axles are in good working order.
Old Apr 26, 2009 | 10:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 10 bolt to 9 bolt BW
Either way, you'll need to swap the proportioning valve--and speedo gears if the ratio on the second rear is different.
JamesC
Old Apr 26, 2009 | 12:46 PM
transamice's Avatar
Car: 87 GTA t-top
Got the prop valve as for the speedo gear, im going from 3:23 to 3:45 is there much difference to even bother?
Whats the site for rear disc brake conversions on here?
Theres bigbrakeupgrade and another one who sold brackets for 10 bolts.
Old Apr 26, 2009 | 12:50 PM
JamesC's Avatar
The speedo question is up to you. I'm **** enough to want the speedo to register the correct speed.
Here's Ed Miller's site for the conversion kit:
http://www.flynbye.com/
JamesC
Old Apr 26, 2009 | 01:03 PM
transamice's Avatar
Car: 87 GTA t-top
Thank you,
Just curious if anyone has checked or knows, if the caliper plate on the 9 bolt fit the 10 bolt.
Old Apr 26, 2009 | 01:27 PM
JamesC's Avatar
Thank you,
Won't fit. The backing plates have different bolt patterns.
JameSC
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
