TCI Sat Nite Special Torqe Converter......
Car: 87 IROC Z28
Transmission: TH700R4
I have a 305 TPI with a Compucam 2032 3.73 rear and a 700R4 tranny.... my car seems to be a little sluggish till the cam kicks in at about 2000 rpm... will this torque converer that stalls at about 1600-1800 help my problem or should i go with a higher stall? Need a little more jump off the line.. can anyone give me some advice? Thanks!!
Ant
87 IROC 305 TPI
Ant
87 IROC 305 TPI
More !
I have a stock L98 with a B&M Holeshot 2400 and still want more. Your 305 has less bottom end and you will need more stall to get that 305 out of the hole.
92 Z28 5.7 TPI AUTO 105k factory motor and trans.
SLP headers and runners, B&M 2400 stall, shift kit,LCA brackets, EIBACH spring kit, NITTO'S, N.O.S.
best 60ft 1.84 1/4 12.48 @ 110.81
If you want something that is going to give you results (just not more stall), then I would use the 9.5" A.C.T. torque converter or equivalent. It will give you about 2-4 tenths in the quarter mile, and still retain the lockup. Depending on what the duration of the camshaft is at .050 lift? and what type of driving you do, will pretty much determine what stall you will need or want? I would recommend about 2,500-2,700 with this 305 ci. motor if it is performance you are after! This will work out well with 3.73's, especially with a small motor as your's. If I can be of help, call me at 800 7763288 Mon-Sat 11-7 PST or post it.
Glad Too Help!!!
Glad Too Help!!!
Car: 87 IROC Z28
Where can I pick up this A.C.T torque converter that your talking about and how much is it?
Ant
87 IROC 305 TPI
Ant
87 IROC 305 TPI
HoosierinWA
Oct 7, 2015 10:15 AM
