will i blow my trans
i have a modifyed 700r4 with a 30 spline input shaft. high volume pump, 9 cluchs, transgo shift kit, and vette servo. will a 400 small block chevy with about 430 Hp and 470 ft lbs blow the trans or am i safe.if it makes a dif i have a 3000 stall converter. thanx
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
R.I.P #3
If properly assembled and with a good Sprag that should be no problem. Do you have the .477 Boost Valve? That should be used with that setup.
[This message has been edited by transfixleo (edited August 09, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
maroe624
Apr 16, 2017 08:29 AM
Hello, Michael
Aug 20, 2015 03:19 PM
