Help!!!!!Carrier Question ????? QUICK
Old Aug 9, 2001 | 09:43 AM
RED89GTA's Avatar
I posted about the richmond gear, now I found out they have 1 for 3:08 carriers and lower, and then for 3:23 higher, I got the rearend from a junk yard, it has an open rearend thats all I know!!!!! what do you think the size of the gear is????
Old Aug 9, 2001 | 10:36 AM
92Camaro305TBI's Avatar
What car did you get it from.. If one at all?
Old Aug 9, 2001 | 10:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Open it up and look. It's too far from your monitor for the rest of us to see into it any better than you can.
ICON Motorsports
Old Aug 9, 2001 | 09:18 PM
82camaro's Avatar
Car: 82 camaro SC
Count the teeth and divide them to find the ratio. Then you will know.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
knight72
Aug 10, 2015 09:32 PM
