t-5 same size for V6 and V8
Old Aug 10, 2001 | 12:08 PM
Electromaro's Avatar
is the t-5 out of a 87 z28 with an lg4 engine the same as a t-5 out of an 87 firebird with a V6. is the bellhousing the same? the clutch? is the slave cylinder located in the same place. i believe the v-6 car has dual exhaust, is this a problem? thanks
Old Aug 10, 2001 | 12:41 PM
Rylos's Avatar
The V6 t5 has a 13 spline input shaft
The V8 T5 has a 26 spline input shaft.
This there for the chutch form a V6 T5 will not work on the V8 t5 and vis ver!
Gear ratios are also different between the two.
you can get a 10.5 clutch disk for the V6 T5 but it is under the sunoma truck part listings.
Other that that there the same !
Old Aug 10, 2001 | 03:37 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
and remember that the bellhousings are different all together. you'll have to use a V8 bellhousing since the V6's in fbodies were 60* engines.
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Aug 10, 2001 | 04:08 PM
ok, would a v8 t-5 b&m ripper shifter fit on the v6 t-5? thanks guys
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
