700R4 build up
Old Aug 10, 2001 | 07:21 PM
red350Z's Avatar
700R4 build up
im planning on rebuilding my 700r4. anyone have any tips or tricks i should get done.parts recomondations how about conv.
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
new motor in
Old Aug 11, 2001 | 05:12 AM
transfixleo's Avatar
TransGo Rprogramming kit and the Hi Rev release springs that come with it. TransGo Hi Rev Pump Ring Kit. 4l60E 3-4 pack and Input Sprag Assembly. All Borg Warner frictions. Corvette rear planetary. NEW GM Sun Shell. Minimum endplay settings. Depending on power, 553 Servo or 093 (Vette). .422" PR Boost Valve for small block, .477 for big block or HIGH power small block. .282 Int/Rev Boost Valve. TruCool LPD cooler and bypass the radiator.
The converter choice depends completely on the power band of the engine. Your stall should be at or just below where your engine STARTS to make power and the WOT shift points should be set so that it is completed BEFORE the power starts to fall off (NOT your max RPM). A top quality converter supplier is Continental: The number for Continental Converters in Inglewood Ca. is 1-310-674-1072
[This message has been edited by transfixleo (edited August 11, 2001).]
Old Aug 11, 2001 | 02:48 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
http://www.transmissioncenter.net/highperflist.htm
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Aug 11, 2001 | 05:57 PM
Jay 727's Avatar
I would build it as Leo says and use the vette servo or bigger and the bigger boost valves if you like firm shifts and have anything other than a stock engine.
I have a 700 in an S-10 with the 553 servo shimmed without the cushion spring and the .471/.282 valves, it shifts strong especially because it weighs a light 3000 pounds.
I would also go to the transmission center for parts since they have a picture and detailed description of most parts they sell.
[This message has been edited by Jay 727 (edited August 11, 2001).]
junior419
Apr 7, 2025 11:35 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Jorlain
Oct 8, 2015 01:57 AM
89newfun
Sep 16, 2015 09:28 AM
