throw out beaing noise when clutch is not pushed in
Old Apr 30, 2009 | 08:25 PM
nevernamed's Avatar
Car: 87 IROC
Engine: 434
Transmission: TKO600
Hi everyone,
Having a problem with my clutch. It makes a fairly high pitch squeaking noise when in neutral and no pressure on the clutch pedal. If I depress the pedal slightly, the noise goes away. I have taken the tranny out for a different issue and I noticed that when the clutch pedal is not pushed in, the hydraulics push the throw out bearing against the pressure plate. I assume this is the normal automatic adjustment taking place, but is there a spec for how much it should be pressing? Seems like there is fairly significant pressure there, just wondering if that is normal. The bearing and clutch are both new. I don't want to put everything back together again without getting this fixed.
Old May 1, 2009 | 07:53 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
Re: throw out beaing noise when clutch is not pushed in
See this tech article:
https://www.thirdgen.org/squeelingclutch
Old May 1, 2009 | 10:25 PM
nevernamed's Avatar
Car: 87 IROC
Engine: 434
thanks!
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
