cooler lines
Car: 1989 Camaro
Engine: building a 350
Transmission: TH350
Axle/Gears: soon to be 4.10 non posi
cooler lines
So Im in the process of making my trans cooler lines and I realized I dont know which line is which- On my th350, looking at it from the side, the upper line goes to the top of the radiator, or the lower radiator? Im assuming thats how it would be but i dont want to bend the lines and realize im wrong.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: cooler lines
It doesn't really matter but the top line normally goes to the top of the tranny and the cooler.
Car: 1989 Camaro
Transmission: TH350
Re: cooler lines
Sorry,
I think that sounded more confusing than I wanted it too,
I meant I think the top line from the trans should go to the upper fitting on the radiator and visa-versa
am I right?
am I right? Senior Member
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: cooler lines
it doesnt matter which goes where.
typically, you would bend them so that they stay parallel (offset the same distance) and the one coming out the top from the trans would go into the top hole, BUT, if its easier, or you mess up, and get it backwards, it really wont matter.
its going through the radiator either way and cooling off just the same.
