swap a 700r4 for a trans from a 91-92 camaro
Old Aug 11, 2001 | 08:56 PM
budfreak's Avatar
does anyone know if i can swap a tranny from an 87 trans am gta(700r4) for a transmission from a 1992 camaro RS(4L60)?
Old Aug 11, 2001 | 09:09 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I thought they were basically the same transmission; just the newer ones were built better.
Old Aug 12, 2001 | 05:32 AM
Jay 727's Avatar
They are in fact basically the same, sometime between '87 and '92 they changed the name of the 700R4 to 4L60, same trans. However in '93 they changed to 4L60E, the E meaning it's shifted electronically and that trans is slightly different than earlier 700R4/4L60's.
So your tranmission swap should not be a problem at all.
[This message has been edited by Jay 727 (edited August 12, 2001).]
Old Aug 12, 2001 | 04:23 PM
Pro Built Automatics's Avatar
The 1992 is a better transmission all the way around when compared to a 1987.
Old Aug 12, 2001 | 11:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The f-bodies got the 4L60E in 1994, not 93.
Yes you can swap transmissions, just re-use your stock speedo module from your trans. the 90-92 ones are 4000 pulses while yours is 2000 pulses.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
