T5 Transmission Options
Old May 1, 2009 | 09:40 AM
FLYNLOW92rs's Avatar
Old May 1, 2009 | 05:20 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: T5 Transmission Options
There are shops out there that make upgraded internals for the T5, giving it a torque rating of 450 ft-lbs. But the cost is steep enough to consider a Tremec TKO500. If you use the '88-up World Class version, and drive it like your grandparents would, then a stock T5 should live.
Old May 1, 2009 | 05:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by FLYNLOW92rs
Can the T5 be built up to handle the 350 or do I need to go the T56 route?
I'm looking at the 300-350 HP range, nothing about that since the car still needs to be somewhat reliable.
If you don't drive like it you stole it, even a non-WC will be fine. Mine has held up without any difficulties behind my 350/330 (I am, however, a four-time grandfather). Sticky tires, dropping the clutch, etc. is a sure end. I've read that regardless of the upgraded internals, the case will still present a problem. Should very spirited driving be your habit, I'd suggest an after market.
JamesC
Old May 4, 2009 | 09:42 AM
Old May 4, 2009 | 09:45 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
