rearend kicks out
Old Aug 12, 2001 | 10:32 AM
88greyiroc's Avatar
rearend kicks out
my iroc has 2.77 it is suppose to be pos. but i know i shouldn't be doin this but when i try and do a donut only one tire spins but when i do a burn both tires smoke . the car isn't workin good now but i was just wonderin if there was anything i could add in the rear end because iam pretty sure the clutches are worn out or somethin .
Old Aug 14, 2001 | 01:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Your posi sounds normal to me- it's working correctly. See, if you're doing a donut, only one tire should spin. You can't have both tires spinning while you're turning; that's equivilant to a "spool"- and if that happened, you wouldn't turn too well! One tire is supposed to go along for the ride, while the other tire does the pushing. I believe the "inside" tire does the work, and the "outside" freewheels. That goes for any posi or locker, even an "open" rear.
But if you're heading straight, both tires should spin.
-Tom P (Hot rodded 1986 Firebird 2.8l)
junior419
Apr 7, 2025 11:35 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
L0tuS
Oct 4, 2015 08:07 AM
Giocio
Oct 1, 2015 12:20 PM
tattmann
Sep 27, 2015 05:20 PM
