Motor Swap, now I have no Lock up
Old Aug 14, 2001 | 10:26 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Any suggestions on how I should hook up my lock up. When I swaped my 305 tbi for a 350 carb I tried to plug in as much electrical stuff as possible. The only thing off is the TPS and the coil and distributor wires. I was kinda hoping that the computer would still control it. I know I can do a toggle switch, but I was told there was a way for lock-up to come on when ever the tranny shifts to overdrive. Any help, I hope this will improve the mileage I lost.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 350CI, 2bolt,.030 over, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Old Aug 15, 2001 | 12:02 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Run the wire from the pressure switch to the black side of the solnoid. Run the other side of the solnoid to terminal "A". As long as 12v is applied to "A" it will lock up in 4th. Some trannys have solnoids with only 1 wire, but most 88's i've spotted have the 2 wire so you should be OK.
Old Aug 15, 2001 | 12:12 AM
BringBackThe80s's Avatar
SC88, I've been looking for the same answer myself, fixing to drop a 400 with non CC carb and distibutor. Let me know how this works out. You can e-mail at DanAndAmyInNC@aol.com
Good Luck!
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
st.evel07
Aug 13, 2015 06:15 PM
