1987 700R4 Check Ball Locations
Old May 4, 2009 | 08:08 PM
begakicks's Avatar
I've got a bit of a dilemma.
I have a 1987 700R4 transmission with the aux valve. I've been having an issue getting it to shift from 1st to 2nd. I think it might be an issue with the checkballs on the valve body.
Does anyone know how many checkballs should be above AND below the spacer plate on the valve body?
Also, does anyone have any images that might help me make sure I have the checkballs in all of the right places?
Let me know
Thanks for the help.
Old May 6, 2009 | 09:51 PM
TorqueBeastZ28's Avatar
Re: 1987 700R4 Check Ball Locations
go to this site and download the intructions be carefull to use the diagram that shows the checks ***** before the shift kit. http://www.bmracing.com/PRODUCTS/Bui...TH-700-R4-4L60
Old May 7, 2009 | 02:29 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
in the channel plate you need four, and two in the valve body. The big one in the channel plate is commonly left out. don't install the #9 detent low ball as there is a capsule ball below the plate to take the place of the #9. The #9 is also known as location A. it is the closes ball location to b#4andc#8.... #9 in the channel plate it is the one closest to the shifter. The big one in the valve body is left out also in an aux application, so put 2 small ones in. Hope that helps. P.M. me if you want to call me about it.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
Out-Cast
Aug 17, 2015 10:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
