Help with speedo gear questions..Please!
Well I'm finally getting around to installing my 3.42's. A noticeable change I hope from the 2.73's . Anyways , my 86 Trans Am appears to have the electronic sensor on the tailhousing. I've gotten the info on the speedometer gear changes I need to do (15 tooth gray #8642620 drive and 41 tooth yellow #25513048 driven ). But what about this sensor. Does it also have to be replaced or can the existing one be used
Car: Take
Engine: Your
Transmission: Pick
It can be re-used. Check out this link: Speedo Gears
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited August 19, 2001).]
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
