turbo350
Old Aug 14, 2001 | 10:34 PM
Rice_Cooker_'88's Avatar
turbo350
hey guys. i can get my hands on a CHEAP turbo350 tranny and was wonderin gif it would be worth it to put it into my '88 camaro. right now i have a 700 r4. thanx
Old Aug 15, 2001 | 04:09 AM
transfixleo's Avatar
What is your goal, lower gas mileage or less acceleration in 1st and 2nd, or maybe a hotter running tranny at cruise? In other words, why take a step backwards? Not to mention CHEAP is usually another word for junk.
[This message has been edited by transfixleo (edited August 15, 2001).]
Old Aug 15, 2001 | 06:22 AM
82camaro's Avatar
Car: 82 camaro SC
I swapped out my th350 for a 700r4. My cruise rpm went from 3000rpm at 60mph to 2150rpm at 60. The th350 is a strong tranny and has it's purpose, but if you drive down the highway/interstate much the overdrive is very nice.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 19, 2001 | 04:58 PM
CrazyRob75's Avatar
I just put mine in 3 weeks ago and LOVE it. Obviously i misss the OD. It al depends what your going t6o do with the car. TH350 is stronger( for cheaper) but at the expensive of losing OD
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes freshly installed th350 3200 stall, shift kit, reworked valvebody, Megashifter, Biondo linelock ..........YES, it's street driven!
check it out at http://www.bsronline.net
Jrzyboy
Jul 30, 2012 06:18 AM
GreggymacZ28
115
Jun 5, 2012 07:26 PM
DLTrahan83
Oct 23, 2002 08:11 PM
