t56 gear ratio
Old May 7, 2009 | 06:44 PM
squatingeagle's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.23 posi
t56 gear ratio
im looking into a t56 swap and i understand there are different t56's. lt1 vs ls1 vs retro. i also remember something about different lt1 t56's. i have read the difference in their gear ratio's on one thread but i cant find it again. can someone please either direct me to it or let me know the different ratios per t56.
thanks
Old May 8, 2009 | 02:13 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: t56 gear ratio
93 LT1 T56
Borg Warner T56 6-speed Manual
Gear Ratios : 3.36, 2.07, 1.35, 1.00, .80, .62
& 2.97, 2.07, 1.43, 1.00, .80, .62
Spline : 26 input/27 output
Dimensions :
Torque Rating : 350 lb-ft & 400 lb-ft
94-97 LT1 T56
Gear Ratios : 2.66, 1.78, 1.30, 1.00, .74, .50
Dimensions :
Torque Rating : 450 lb-ft
98-02 LS1 T56
Dimensions :
Copied from here
Old May 8, 2009 | 04:56 PM
Car: 91 Z28
Re: t56 gear ratio
thanks calebzman that was exactly what i was looking for
note to self
93 LT1 T56
Gear Ratios : 3.36, 2.07, 1.35, 1.00, .80, .62======= RPO ?MN6?
& 2.97, 2.07, 1.43, 1.00, .80, .62======= RPO M12
Dimensions :
94-97 LT1 T56
Gear Ratios : 2.66, 1.78, 1.30, 1.00, .74, .50====== RPO MM6
Dimensions :
Old May 9, 2009 | 09:54 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: t56 gear ratio
For a third gen swap the '94-up LT1 T56 is the prefered unit. Plus the .50 6th gear is amazing. My car turns 1,800 RPM at 80MPH with 3.73 rear gears.
Old May 9, 2009 | 08:33 PM
Car: 91 Z28
Re: t56 gear ratio
wow... i didnt think it would be any where near that low with 3.73's. that is amazing. most likely what i am going to do with mine
Old May 10, 2009 | 10:12 AM
rippin ron's Avatar
Car: 91 Camaro RS
Axle/Gears: 4.10
Re: t56 gear ratio
And the GTO t56 has 2.97, 2.07, 1.43, 1.00, .84, .57 ratios.
Hotrodboba400
Dec 10, 2019 07:07 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
