How to go about getting a posi and 3.73 gears
Old May 8, 2009 | 10:13 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
I was wondering if there was a way i could make my rear end a posi and 3.73 geared for around 600 bucks ? Any Ideas?
Last edited by tyler92; May 8, 2009 at 10:15 PM. Reason: Trying to be a little more clear
Old May 9, 2009 | 06:39 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: How to go about getting a posi and 3.73 gears
Better start saving more money, because $600 for Parts & Labor is not going to cut it. A Eaton limited slip is well over $400 to start as example.
Old May 9, 2009 | 07:12 AM
big gear head's Avatar
Eaton Posi $445, 3.73 gears $170, inastallation kit $92, labor to install $250 to $400. If your axles are worn then they need to be replaced too. Axles, bearings and seals $270.
Old May 9, 2009 | 08:45 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Summit Racing gears , install kit , and a Powertrax Lock Right locker come in at $624.85 before shipping and that doesn't include gear oil or axle bearings and seals that you should replace when you do a gear swap so everything is new .
Old May 9, 2009 | 09:17 AM
And with that you are going to get a set of noisy gears, cheap bearings and a shim set that is hard to use.
Old May 9, 2009 | 09:28 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
I have no experience with rear end work so I will have it done in a shop . Thanks for the help. So Eaton is the way to go?
Old May 9, 2009 | 09:59 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Eaton or Yukon (from Randy's Ring & Pinion). I had a Lock Rite, and I definately do not recommend it. The car was clunky when cornering and I couldn't see the benefit over a posi. High speed cornering was a bit unpredictable too, as you would get snap oversteer when the locker finally unlocked. Stick with a posi.
You should be able to get the gears set up for $250. Find a shop that works on a lot of 4x4s. They do this work all the time and are fast at it, so they can charge less than a shop that only does one or two a year.
Old May 19, 2009 | 04:21 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Thanks for the good advice
Old May 21, 2009 | 05:58 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Detroit truetrac.
Old May 21, 2009 | 06:20 PM
squeeezer's Avatar
Car: 5 cars
i agree with the info on the lock right/powertrax locker if in a handling car
in a 1/4 mile strip car only that you can cruise the streets (not much for handling) they are a good alternative
i had one in both types of suspensions......yeah i got rid of it in my handling car
i have 1 for sale......26 spline though (power trax)
Old May 22, 2009 | 09:16 AM
How much? I know some dirt track guys who would like to have it. Send email to biggearhead@bellsouth.net
Old May 26, 2009 | 05:16 PM
squeeezer's Avatar
Car: 5 cars
id have to find out how much for shipping
$100 + shipping is a good price i think
Old May 26, 2009 | 06:25 PM
I'll see if they are interested. Is it the Lock Right?
Old May 27, 2009 | 07:45 AM
squeeezer's Avatar
Car: 5 cars
if i remember right the "lock right" is by "powertrax"
i have 1 of each 1 is a 28 spline (currently in use)
and the other is a 26 spline up for grabs
1 is a powertrax the other is a lock right i dont remember which is which cause they look identicle
Old May 27, 2009 | 08:51 AM
I still have mine and would be willing to sell as well. It's for 28 spline axels though. Lock Rite, very little use (maybe 3,000 miles). I still have the manual, etc. Anyone interested can contact me at KrapfHomes@aol.com or send me a PM.
Old May 27, 2009 | 09:19 AM
Power Trax (now owned by Richmond) makes the Lock Right and the No-Slip. The Lock Right is good, the No- Slip is usually junk. I can probably sell the Lock Right to these guys if they have the money. I just wanted to be sure that it is a Lock Right and not the No-Slip.
Old May 27, 2009 | 09:27 AM
I'm looking at the owner's manual right now. Powertrax Lock Right.
Old May 27, 2009 | 09:41 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Im thinking it may be easier to just get a 4th gen rear end.
Old May 27, 2009 | 10:34 AM
You'll have to change the rear wheels to make a 4th gen rear work. With stock 3rd gen wheels the 4th gen rear will make the tires stick out past the wheel lips on the quarter panels, which is not legal in any state I know of.
4th gen rears also won't work with drum brakes, so you'll have to convert to disc if you have drums. This means new e-brake cables and hardware, new master cylinder, and new combo valve.
Cost wise it's probably cheaper to build what you've got. Hassle wise, if cost isn't an object, the 4th gen rear is easier for someone who can't set up their own gears.
F-body driver
Mar 6, 2023 11:44 AM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
