Rearend Gurus please read inside Part II
Old Aug 23, 2001 | 10:04 AM
vortech305's Avatar
Sorry, but i couldnt read the first post because some idiot closed it or something, my question was my friend is building a worked 355 motor pushing 429 hp at the crank.He's using a th350 tranny,w/streetfighter torque converter, He has 2 rearends readidly available
1) 7 1/2 10 bolt w/ 3:73 and posi unit
2) 7 1/2 9 bolt w/3:73 from SLP and limited slip differential, which rear could handle the 420 hp the crank will be pushing, thanks
Old Aug 23, 2001 | 11:45 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, I'm no guru, but I have always read that the 9 bolt rear is slightly stronger than the 10 bolt, ecpecially the 7.5" 10 bolt.
BTW, in the 9 bolt rear end, the 3.73 gears are really 3.70, 10 tooth pinion on a 37 tooth ring gear.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 3000 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(40psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.27sec @ 103mph on MT ET Streets
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Aug 23, 2001 | 02:24 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
It wasn't locked, it was moved from the body/interior board to the trans board. It should be on both boards and my answers are there.
Miles
EDIT - I am not sure what that is all about??? Anyways, below is what I posted.
The 9 bolt is stronger than the 10 bolt by far! It has 4 pinion (spider) gears and 2 side gears vs 2 & 2 in the 10 bolt. The 9 bolt has axle retaining flanges vs C clips. The 9 bolt can be serviced for longer life, the 10 bolt can't.
I now have parts available for 9 bolts (new carriers and gear sets, - other stuff is coming soon). They are not as cheap as 10 bolt stuff, but they are a lot cheaper (and lighter) than a 9 inch (or 12 bolt) and much stronger than a 7.5 (or 7.625) 10 bolt. I have been running a 9 bolt behind my big block (500hp 520lbft) for almost 3 years now with 1.72-1.75 60 ft times. So have other people. I can get ratios from 3.2x to 4.1x.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
[This message has been edited by 88 427 Camaro (edited August 23, 2001).]
armybyrd
Aug 17, 2015 08:59 AM
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
z28addict8490
Aug 7, 2015 08:48 PM
