4th gen rear
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: 4th gen rear
That's a heavily loaded question. Short answer no. Long answer yes, but with a lot of caveats.
Yes, if the axels are in like new shape, preferably if they've been replaced with new ones from Moser, Yukon, or Superior. And if you don't forget the cap stud kit when you do the girdle. And if you use a solid pinion spacer instead of a crush sleeve. And if you use a new posi unit from Eaton or Yukon (The stock spiders are suspect, and could fail with catastrophic results). And if the gear setup is perfect, preferably using new Yukon gears. And if all the bearings and races are new Timken units. And if you stay away from outright slicks. Sticky stree tires will be fine, and DOT slicks will be okay; for a while...
It can be made to live, but I don't want you to have any illusions. Most guys that are serious are running a 12 bolt or 9", and there's a reason for that. There are just too many unknowns in the strength of drivetrain parts to give a definite yes, unless there's overkill built into the equation, which you have with a 9" or 12 bolt, but not so much with a 7.625" 10 bolt.
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: 4th gen rear
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
