can you put the electric speedo sender on a trans with a mechanical sender?
Old Aug 23, 2001 | 09:04 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Topic says it all. I have the 700-R4 in my '86 IROC that someone smartly ( ) changed to an early '84 unit. I had the tranny built and aferwards I found out by the builder that it was the 27 spline (greeeat). I may use it temporarily behind my 350 before I break it, but will replace it soon eitherway...my friend wants it for his very low-buck '89 305 TBI IROC that has a slipping tranny and the 30 spline trans. I know it's got the electrical speedo...it looks like I could swap the two senders...what is involved? Do I change the tailshaft housings or just the senders...gears in output shaft...is it even possible? Please let me know before I sell him my tranny...would suck to pull it out and find out it won't work! Thanks!
Old Aug 24, 2001 | 12:14 AM
AUTOGON350's Avatar
Car: 93 S10 blazer
I just recently was facing the same issue with a tranny that I bought. The owner of the local speed shop said that the mechanical ones can be changed to VSS.
I dont know how complicated it is but IM hoping not very because I will soon have to do it too.
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
Old Aug 24, 2001 | 02:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're smart enough to operate a 10mm box wrench, you can do it.
Old Aug 24, 2001 | 08:42 AM
dhirocz's Avatar
Cool. I was hoping it didn't use a cast gear or something the required changing the ouptput shaft or some similar thing. Looked straightforward...thanks for the help
Old Aug 24, 2001 | 09:30 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
dhirocz,
Your friends 89 IROC still uses a cable driven speedo. Camaro's didn't get the electronically driven speedo until 1990. Birds got it around 87.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Aug 24, 2001 | 11:44 AM
dhirocz's Avatar
Oh, well that clears up the air! Now that I think of it, my Dad's '84 T/A and my Mom's '88 GTA are different...the GTA is an electronic speedo. I thought they were both the same year. That helps alot! thanks!
Jorlain
Aug 24, 2022 05:11 PM
RazorN8
Jan 7, 2022 11:44 AM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
