Auto Over ride?
Old Aug 26, 2001 | 09:09 PM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
Auto Over ride?
I herd there is part that Overrides something in the tranny so when you rev the engine up high in nuetral and you shift ito drive, the Revs dontgo down the stay at the revs you had it up to in neutral....O know this sounds complicated and it is hard to understand but I have no other way of explaining it....Thanks
Old Aug 27, 2001 | 08:36 AM
82camaro's Avatar
Car: 82 camaro SC
Sounds like a neutral drop. Never a good idea.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
sp8ty
South East Region
Sep 24, 2018 03:55 PM
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
