B&M Shift Kit or a Transgo??
Old Aug 22, 2001 | 08:03 AM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Which is the better kit? I can get a B&M Shift Kit for my TH-700R tranny for $60.00 (PN 70239)... doesn't look like a hard install either.
1987 Camaro Iroc Z
350 TPI..TH700R
Old Aug 22, 2001 | 08:31 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Most people say B&M kits are junk. Get the Transgo Reprogramming kit.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 22, 2001 | 10:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I was about to yell "$60, are you nuts?!", but then I noticed you're from Canada, I forget about the price difference. (Summit Racing sells that 70239 kit for $30 US.)
I have the B&M #70239 in my trans, it's alright, but too many guys in-the-know don't like it. I wish I knew that a few years ago- I would've spent the extra for the TransGo reprogramming kit.
But it was a simple install; messy & "scary", but overall, simple.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 22, 2001 | 11:21 AM
87ROCZ's Avatar
Yeah I'm a Canadian...where the beer is cold and the women are hot!! hehehe...
Guess I will look into a Transgo. Does Summit have one??
Old Aug 22, 2001 | 01:13 PM
Car: 99 Formula
Axle/Gears: 342
Yes, summit sells the kit, I believe it is around $170.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Old Aug 22, 2001 | 08:34 PM
GeneralHazzard's Avatar
hey northern sells shift kits and i was wondering if theyre the same. it says, Shift Improver kits: Trans Go No Yo Yo Fixes the problem that causes Transmission failure.
are these the transgo kits everyone talks about? for the 87 up 700r-4 its pn K61908J price: $19.99 or **K61908 This Kit Contains: Servo, Accumulator, Governor and Valve Body Parts and fits same application as K61908J price: $36.99
This seems awful cheap compared to 130 in summit. anyone have experience with these? sounds like a deal no matter what.
Old Aug 23, 2001 | 05:19 AM
transfixleo's Avatar
That sounds like the full Shift Kit and the Shift Kit Jr., for later cars that don't have the shift timing problems that the earlier 700's had. Be advised that these are true Shift Kit's and therefore are not going to give you excessively firm shifts, just fixes the weaknesses in them. Also be advised that these ones are intended for professional instalation so buy a manual to go along with them. The more expensive kit is the Reprogramming Kit which is more performance oriented but still fixes the weak points. try this: http://www.hptransparts.com/MM007.ASP?pageno=89
Old Aug 23, 2001 | 09:12 PM
well they got em listed for all 700's, powerglides, 4L80E, TH400,TH200C, TH200R4, TH350/350C, 4L60E, all of em for under $40. all the 700's are $19.99, the 350 200 and 400 are $15.
so you think the $36 kit and a .500 boost valve do good?
[This message has been edited by GeneralHazzard (edited August 23, 2001).]
Old Aug 24, 2001 | 09:12 AM
87ROCZ's Avatar
I checked that Webpage and it says its a Transgo Reprogramming Kit...
TransGo Reprogramming Kit 700-R4 1982-91
#HP98357 Performance Stick shift or automatic kit 700-2&3
Combo High performance or Competition for racing.
Higher shift points, higher pressures, hard, quick shifts.
This one goes for $81.00...
What do you think of this kit and this part??
High Performance Boost Valve 700-R4 & 200-R4
#HP35333A TV Boost Valve .500" Install this new Valve & sleeve for an instant increase in TV line pressure!
The total would come to $90.00 US...I could handle that if this is a real deal Transgo.
I am going to be doing a Trans Fluid/Filter change soon and seeing I will have the cover off I may as well put in a kit.
Can someone in the "know" let me "know"?
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
350 TPI
TH-700R-4 Tranny
Old Aug 24, 2001 | 04:24 PM
That is the TransGo Reprogramming Kit. I don't think I would go with the .500" Boost Valve though. For a small block they recommend .422", which you probably have and a big block gets the .477".
Old Aug 24, 2001 | 09:32 PM
Pro Built Automatics's Avatar
I carry the Trans-Go 700-2-3 Performance Shift kit $78.00, .471 or .500 main boost valve $10.00, .296 intermediate/reverse boost valve $15.00, Corvette servo with the new updated Viton seals $22.00, and anything else you might need for this unit. Call me if I can be of help at 800 7763288 Mon-Sat 10-6 PST.
Old Aug 27, 2001 | 01:25 PM
87ROCZ's Avatar
Thanks for all the advice!! I will probably look into a shift kit next spring!
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
350 TPI
TH-700R-4 Tranny
"Better to look at it than to look for it "
Hotrodboba400
Dec 10, 2019 07:07 PM
roysatikas
Sep 7, 2015 08:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
