Trans for procharged383
Old May 16, 2009 | 12:20 PM
Proiroc's Avatar
Hi!
I got a sbc 383 with a procharger, i need a new transmisson and drivetrain, i guess a th700 original driveshaft and a 10 bolt dosent last long.. What do you recomend ? th400 + 12 bolt?
Old May 16, 2009 | 12:57 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Trans for procharged383
A 700r4 can be made to take the pain of that unless you're talking something like an f-1 or larger procharger. For the axle, just anything common should be fine being the 12 bolts, ford 9", or the dana 60. I'd go for the th400 if it's pretty much a drag car. I wouldn't use anything without an overdrive or lock-up converter if you intend on using it on the streets. Seems like there are an increasing number of cars using the 4l80e tranny with a valvebody that doesn't need computer control.
Old May 19, 2009 | 01:38 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Are there any physical size differences between the 4L60E and the 4L80E? I've been looking into options for my build as well.
Old May 19, 2009 | 10:20 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I'm pretty sure there is a size difference, but how much and where I don't know. I may be finding out sometime this year if my buddy gets his wrecked truck back from insureance so I can buy the motor and trans out of it.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
