what parts for my 700r4 rebuild.
i was going to order a rebuild kit from pro-built.net, but the rebuild kit they have is like $400.00. it is sold with a shift kit from transgo, which i dont need. so i need all the parts except for the shift kit. so what all do i have to buy? i was thinking like:clutches,clutch bands,clutch plates,and the 3-4 clutch pack. i also want all the vette servo parts. what else do i need for my rebuild? by the way i want to get a corvette converter too.
1986 WS6 pontiac trans am
5.0 305 TPI V8
700R4 tranny w/transgo shift kit. borg warner wires,accel cap and rotr,delco plugs, K&N
KYB shocks,dynomax high flow cat,3"intermediate pipe,40 series flowmaster
w/2 3" tailpipes.
"ponys can run but birds can fly"
www.community.webshots.com/user/kernel20
5.0 305 TPI V8
w/2 3" tailpipes.
Car: 88 Firebird WS6
You may also need a paper and rubber kit, bushing kit, thrust washer kit, pump rebuild kit... I'm not familiar with their kits, so it may be included....
If not you can get them seperate from http://www.hptransparts.com
You may not even want to change the seals and bushings, most people I know don't as it takes longer to do this than change the frictions 2x over. I always do everything and usually rebuild the pump and replace the drum, as the performance bands are wider and don't match the original wear pattern, plus the teeth are usually hammered to hell.
LT1Formula
20
Nov 14, 2015 12:02 AM
