Transfixleo??
Old Aug 30, 2001 | 09:51 PM
85camarman's Avatar
Transfixleo??
Well I got the valve body out and pulled the valves. should they be that hard to pull, some of them seemed to hang up?
Old Aug 31, 2001 | 04:38 AM
transfixleo's Avatar
The aluminum sleeves can be a little stiff coming out but none of the valves should be. You might need to give them a little push with a pick but once the valves and bore is clean they should flop back and forth in the bore (W/O the springs of course).
Old Aug 31, 2001 | 08:38 AM
85camarman's Avatar
That's what I thought, Might have to do some fine tuning some had minor scoring.
THANK'S for your help
Should I look for anything else?
[This message has been edited by 85camarman (edited August 31, 2001).]
Old Sep 1, 2001 | 07:03 AM
To clean uo the scoring do not use sandpaper. Take a fine file and turn the valves as you slowly move the valve accross the file. You are just trying to knock off the high spots, not actually make the valve smaller. Sandpaper tends to round the sharp edges of the valves that are supposed to sweep out any debris.
ajh87iroc
May 15, 2009 08:51 AM
ChevyLuva3
Feb 5, 2002 07:46 AM
b92z28
Dec 12, 2001 04:37 AM
Dyno Don
Nov 2, 2001 04:10 PM
Eddie
Jun 15, 2001 04:46 PM
