Why is my tranny shifting like this?
Old Sep 1, 2001 | 07:58 PM
RICHRAD's Avatar
Ever since I purchase my 86 Trans Am a year and a half ago, my transmission has shifted nice and firm when cold( just as I like it). But when it gets up to operating temp its just too soft for me. Is it my trans fluid. I'm sure its the original fluid. Any thoughts, Thanks
Old Sep 1, 2001 | 10:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sounds like you need a tv cable adjustment. You can look at my last post "NEW GEARS NOT WHAT I EXPECTED" and transfixleo states how to adjust the cable.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 2, 2001 | 09:18 AM
RICHRAD's Avatar
Well, it seems to downshift from gear to gear just fine. Iguess I just have more power coming from the motor before it warms up. Do I need a shift kit to get this firm shifting when hot?
Old Sep 2, 2001 | 08:09 PM
91rscruiser's Avatar
same thing happens with me.i just got a K&N open element and accell ignition,so now when i run cold it kinda sorta almost chirps the tires when it shifts into 2nd.hell the other morning when the roads were wet i got the *** end to swing out a bit(its an open diff).cool as hell.but then it warms up and that ballsy feeling goes away and all is normal.but im getting a shift kit put in this week so that should cure my slush box woes a bit.
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims
-L03 305,TH700R4,2.73's,only mods for now is a Flowmaster 80 series replacement muffler,accel wires and coil,14x3 open element,catco cat,and B&M shift kit.
-best 1/4 mile times to date:16.2@84/2.37 60ft
Old Sep 2, 2001 | 08:42 PM
RICHRAD's Avatar
So I guess the trans likes the colder fluid until it heats up and thins out huh?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
