TH700R4 shifting way too high
Old Sep 4, 2001 | 09:28 PM
Iroc n roll's Avatar
I pulled off my plenum and then reinstalled it. I drove around for a bit and the car was normal. I punched it here and there. Then...all of a sudden my car starts shifting at a much higher RPM than usual? What happened. I'm sorry I can't give you the exact RPM because my Tach is screwed....If anyone has info on that It'll be much appreciated as well.
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, Dropped Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to askulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Sep 4, 2001 | 10:16 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Go to the Tech Article on adjusting the TV cable: https://www.thirdgen.org/newdesign/tech/detent.shtml
Even if it is out of adjustment by a click or two, it will make a big difference on your shift points.
Old Sep 5, 2001 | 03:45 AM
transfixleo's Avatar
Use that for visual reference only: To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
MAke sure that the cable is free too. If it is kinked or got melted on something...
junior419
Apr 7, 2025 11:35 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
89fast5oh
Sep 8, 2015 09:55 AM
