91 axels into a 84 rearend?
Old May 26, 2009 | 10:27 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Correct me if I'm wrong, but I'm assuming the axels in my 91RS are 28 spline and the axels in the 84 I'm rebuilding are 26......so, can I swap them? The 91 is an open 2.73..the 84 is a posi 3.23. Thanks
Old May 26, 2009 | 10:30 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 91 axels into a 84 rearend?
Your 84 posi will need to be replaced to a 28 spline posi to accept the axles but other than that, they will fit into the older housing.
Old May 26, 2009 | 10:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
They won't swap.
JamesC
Old May 26, 2009 | 11:54 AM
big gear head's Avatar
James, why do you say that they won't swap?
Old May 26, 2009 | 12:09 PM
JamesC's Avatar
I assume the OP wanted to swap axles only, and not the carrier.
JamesC
Old May 26, 2009 | 12:46 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Yeah....James is right, I just wanted to know if the axels would swap w/o replacing the posi. I already spent like $900 on the PBR upgrade from Ed Miller not to mention the $150 summit diff cover.....replacing the posi just aint in the budget right now
Old May 26, 2009 | 05:52 PM
Good call James.
hectre13
Dec 11, 2023 08:14 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
