Puttin TH350 in.
Puttin TH350 in.
im puttin a th350 in my car, i gotta find a good cheep core, so they can rebuild it, I went to the junk yard today lookin around at my options and i saw a couple fullsize vans with v8's and looked like nice tranny, but how do i tell if its th350 or 700r4 or even th400? and then i saw some desil engines, with good lookin tranny's, would that work the same? better? not work at all? what other vehicals came stock with th350's in em? thanks ton!
also what driveshaft will i need?
[This message has been edited by White_Boii (edited September 06, 2001).]
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A TH350 pan looks like a square with a corner cut off. They're more plentiful and the easiest and cheapest to install. The majority of the ones in trucks and vans will be a long tail shaft. cars usually have the short tail shaft. 3" difference. If you use a long tail shaft TH350, the stock f-body 700R4 driveshaft will fit with no modifications. Using the short tail shaft TH350 you need to find a driveshaft from an 82-83 f-body that had a 200C tranny.
The diesel engine trucks have a B-O-P bellhousing and the trannys won't bolt up to a chev bellhousing unless they have a dual bolt pattern. The popular swap for those trucks when the diesel engine died was to drop in an Oldsmobile engine.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
I will only point out FYI that the T-350 was built in 5 lengths that I know of.
A standard 4x4 output shaft is the shortest, then an output shaft for a 208 transfer case, then a 6 inch tail housing, then a 9 inch and finally a 12 inch tail housing shaft .
The 6 inch is common in cars , but was used in early pick ups also. The 9 inch was common in trucks. The 12 inch unit was used in some station wagons.
Car: 82 camaro SC
I'd hate to list a bunch of cars that had a th350 because that same car probably had some different tranny option. The junkyards around here have them pulled, cleaned, and the fluid changed. You just have to ask for a th350 9 inch tailshaft.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 4
Engine: 6
Transmission: 5
They came in virtually every car with a small block V8, or a 6-cylinder, from 69 until about 78. After that they started mixing in some other ones. They also came in practically all trucks and vans.
The Chevy case T-350 might possibly be the most common trans on the face of the planet.
ICON Motorsports
ICON Motorsports
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
70s vans th350 were not long tail, tey were short just like in cars, the pickup ones 73-up were the oddball ones and were the long tail ones.
look for 13 bolts on pan with square shape and one corner hacked off and with a V8 or straight six engine in front of it
