jegster torque arm
Old May 28, 2009 | 02:58 PM
11seccamaro's Avatar
Car: 82 z28
Engine: 60 over 350
Transmission: 4 speed standard
Axle/Gears: moser 9 inch 411
jegster torque arm
wondered if anyone has used a torque arm from jegs that mounts to tranny tunnel instead of transmission?Are they strong?Thanks
Old May 28, 2009 | 07:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: jegster torque arm
a few guys here have it. Its a good piece, just make sure you get the one with the adjustable mount on the rear.
Old May 29, 2009 | 08:32 PM
JEFFK734's Avatar
Car: 1988 camaro 1985 camaro
Engine: 350 LT1/355 carb'd
Transmission: t-5/th350
Axle/Gears: 84 z28 posi/3.08 open diff
i have that setup but havent got car on the road yet (having starter problems)but it should be at least 3x stronger than the stock setup and prob 2x stronger than x member mounted torque arm, plus tunnel mount t/a is 2/3 the length of stock, and also if installed properly u shouldnt need the adjustable t/a
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
