th350 swap drive shaft question?
So I got the trans finally but ended up getting a short tail shaft th350 son now my 700r4 driveshaft isn't long enough... So my question is what do I have to get a drive shaft out of to make the short tail tranny work? what year and model of car can i get one out of....
Thanks in advance guys....
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: th350 swap drive shaft question?
82-83 F-body that came with the TH200c 3 speed tranny.
Car: 87 IROC L98
Only if the car had a Th200C 3 speed. Not all did.
Car: 1991 Camaro RS
Engine: 305 c.i. T.B.I.
Transmission: TH700R4
Axle/Gears: stock open 2.72
The easy way of doing it with the tranny in the car and use a tape measure
Car: 87 IROC L98
The proper length is to slide the slip yoke all the way into the tranny then pull it back out 1". Measure from u-joint center to center. That's the length of the driveshaft to have one made.
Car: 1988 camaro 1985 camaro
Engine: 350 LT1/355 carb'd
Transmission: t-5/th350
Axle/Gears: 84 z28 posi/3.08 open diff
spohn sells a heavy duty driveshaft for 360 bucks, if u have money to burn
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
