2.77 to 3.42?
Old Sep 9, 2001 | 03:24 PM
88greyiroc's Avatar
2.77 to 3.42?
what kind of improvement should i notice i have a 350 tpi iroc now with 2.77 and it will bairly churp in 2nd gear with a shift kit and a computer chip i would like to know what would it do with 3.42 gears?and what should i expect with 3.42 gears?performance wise?
Old Sep 9, 2001 | 04:03 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You will love the 3.42's. They will get ya out of the hole much quicker and give ya a good hit going to second. To me,3.42's are about the best all around gear.You will lso need to correct your speedometer.
Old Sep 9, 2001 | 04:10 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I had a friend that had a camaro with a LT1 vette engine in it with a paxton super charger. When he switched to the 3.42 gears it made all the difference in the world. It didn't seem to rob the car from low end power nor high end. As a matter of fact i was so impressed with them i ran out and put them in my camaro the next week.
Old Sep 9, 2001 | 09:13 PM
Chuck Haynes's Avatar
88greyiroc, if you do go with the gears... list the part #... I sold my 88 IROC-Z to my buddy. It had 2.77's in it. He was thinking about 3.27, but it sounds like 3.42 would be the way to go.
-Thanks
BTW, would it be wise to go to 3.73's?
Old Sep 10, 2001 | 01:53 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
2.77 is a 9-bolt ratio, you have a 9-bolt rear end in your car. You cannot use 10-bolt gears like a 3.42. You need 9-bolt specific gears. They come in 3.27, 3.45, and 3.70. Search this board for 88 427 Camaro (his name is Miles). He is the hookup now for 9-bolt gears and posi units. Or look for other 9-bolt posts.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
dbrochard
Jan 28, 2016 08:42 AM
codeysabatini
Nov 10, 2015 04:07 PM
JSDaddy189
Sep 26, 2015 03:50 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
