Will 4th Gen 3.73 gears swap into our 10 bolts?
Old Sep 9, 2001 | 08:55 PM
RED92's Avatar
Need answer asap if you know, and yes, I have a 3 series carrier.
Thanks!!!
Old Sep 10, 2001 | 01:54 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep! 10-bolt gears are universal.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 10, 2001 | 07:44 AM
RED92's Avatar
Thank you!
Old Sep 10, 2001 | 08:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Well. 7 1/2" or 7 5/8" 10 bolt gears are universal. Older 10 bolt diffs were 8.2" or 8.5". Those won't work.
If you're just swapping the gears then you'll have no problems. If you're swapping the carrier also then you'll need 28 spline axles either from a 90-92 or from the aftermarket.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
