Steps in dropping rear end?
Old Sep 10, 2001 | 12:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
89 FORMULA 350
99 Grand Prix GT
Old Sep 10, 2001 | 12:46 PM
ScreaminDeamin85Z's Avatar
i think this is how i did mine. unbolt shocks, sway bar, driveshaft, torque arm, control arms. i think that was it but i cant remember it was longer than a week ago
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-305 5spd...Jamex Springs...and thats just about it!Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Sep 10, 2001 | 01:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Screamin hit most of the high points.... I would add, the Panhard bar, the hydraulic brake lines, and the parking brake cables. It's about a 2-3 hour job for one person to swap one, with a floor jack and hand tools; 2 people and air tools would make it take less than an hour.
ICON Motorsports
Old Sep 10, 2001 | 04:12 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I found that the easiest way to do it is to put a jack under the hog and remove everything EXCEPT the shocks. Then check & double check to make sure everything is clear. The Torque arm will slide out of the trans mount.
To detail what i usually do:
-Jack up car
-Put jack stands under subframe (just in front of control arm mounts)
-Remove wheels
-Let axel drop, and jack up partly under hog (to support axel)
-remove e-brake cables
-unbolt driveshaft
-remove remove brake line
-remove pan-hard from axel
-Disconnect control arms from axel
-disconnect shocks,
-drop axel and pull out toward rear of car
luckily there are only 5 Bolts, 1 brake line and 2 e-brake cables to disconnect.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
[This message has been edited by okfoz (edited September 10, 2001).]
Old Sep 10, 2001 | 09:25 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Check this out: 10-Bolt Swap
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
