shifting at 2500 under part throttle. and 3rd at 30MPH
Old Sep 1, 2001 | 11:49 PM
breathment's Avatar
ok, i adjusted my TV cable and the shifts can sometime feel violent. alot more firm then before.
Before it would shift into 2nd under coasting conditions or very little throttle at like 6 MPH, now it shifts at like 13 or so, at about 2500+3000 RPMS. and it will wait to shift into 3rd gear at 30 MPH. and before it would shift in OD at 36 MPH now it waits till about 45..
- David
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
Old Sep 2, 2001 | 04:22 AM
transfixleo's Avatar
Part throttle shift points are all relative. Minimum and maximum remove the variance of what throttle position you normally drive at.
What is the WOT shift points?
Old Sep 6, 2001 | 09:02 PM
breathment's Avatar
alright, i think its at about 5400, or maybe even exactly red line, i haven't had a chance to really try cause its been raining, and this morning i finaly got a chance to open it up, only problem is that i might of accidently let of the gas because of habbit (shifts into 2nd at 40 MPH which is speed limit on road i was on, so i might of let off a little so i wouldn't chirp 2nd too loud or go too far over speed limit).. i'll try it again tomorrow all the way down just to make sure. but before i adjusted the TV cable it seemed to shift the same at WOT, maybe even higher.
- David
Old Sep 8, 2001 | 03:37 PM
breathment's Avatar
and another thing, while i wait for ya answer.. shifting into 2nd is more rough then the rest, i mean its dangerous driving the car on wet roads because whether i am accelerating or decelerating, and im turning onto a road and it shifts into 2nd, i will feel the rearend slide about a foot or two. and even dry weather will cause it to slide a couple inches. i know that they shift hard, but this hard? its not so bad with the A\C on cause it seems to really drag on the engine and just seems to shift better.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 10, 2001 | 05:19 PM
breathment's Avatar
top
Old Sep 11, 2001 | 04:09 AM
What 'shift kit' do you have?
Old Sep 11, 2001 | 09:54 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
if i am slowly accelerating my car shifts into OD at 35.....
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
TreDeClaw
Aug 14, 2015 06:58 PM
1nastygta
Aug 8, 2015 07:38 PM
