Very High RPM
Old Sep 12, 2001 | 11:26 AM
vrjg05's Avatar
Very High RPM
I just had my 700R4 rebuilt because 2nd and 3rd gear were burned out. It ran great but then it started to shift really high. I took it back and he fixed it. He said it was the valve that was sticking. But it did not shift wiht firmness like before. Then a week later it did it again. He changed the vavle body and a week after that it did it again. He thinks it is debree from converter. Is this true what can I do to fix this??
Old Sep 12, 2001 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like he needs to pull it out, tear it down, and do it right, including the TC this time.
Under warranty, I might add...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 12, 2001 | 06:08 PM
transfixleo's Avatar
I tend to agree. You may also have 'left overs' in the cooler that are making their way into the tranny. This is why I like to install a TruCool cooler and bypass the radiator. The throttle valve in the VB likes to stick anyways (it is one of the primary causes of failures in these). The TransGo Shift Kit/Reprogramming Kit has a new, redesigned valve in it that takes care of this 99% of the time (as long as something isn't coming apart, loading the tranny).
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
